Yeah nice I just fount the invert axis function. But how can I remove the shortbelts? The pulleys are on the same positions after the swap, arent they?
You can mount the motor onto the axis shaft. You would need to make brackets, maybe buy couplings and longer shafts but as this can improve print quality. If you're going to move them, Why not make improvements at the same time 😃
Labern 772
you can also install tinkerware firmware and should be able to change motor direction. I don't think it would be too much of an issue and also means you can remove the short belts.
