You should not gotten the block v3. That's for UM2 only. Not Um3. Not UMO.
The nozzles however you can use. You should not have taken your head apart at all. You just remove the existing nozzle and screw in the new nozzles directly into the aluminum block.
You can use any type of brass e3dv6 style nozzles meant for UMO or UM2.
This is good to know. I had reached the conclusion that using the nozzles in the old block was probably the only option open to me, but did not want to do this before checking they were compatible.
gr5 2,224
Send it back!
