The naming of Cura Connect is a bit unfortunate IMHO as it doesn't actually connect Cura's but only Ultimakers (in that regard Ultimaker Connect would have been a better name). You're not the first to be confused by that.
Smithy is indeed correct with his assessment. It's probably possible to support the Makerbot API's, but we won't spend any time building it. I very much doubt that Makerbot will put in the time / effort to make such a plugin either.
Smithy 1,114
Cura Connect works only with Ultimaker printers because the second part of Cura Connect is in the printer's firmware.
As far as I know, setup a network printer only works out of the box for UM printers. There is a plugin in the marketplace for Octoprint, to send the jobs via the network to your Octopi, but there is no general network functionality for other brands. I guess you will need a specific plugin for your Makerbot, because it will use a specific API.
