13 minutes ago, ahoeben said:When Cura is starting to become unresponsive, how much memory is it using (according to Task Manager?)
Are you using any plugins? What printer do you use, and how is it connected?
I just checked, on the last freeze it was using 674 MB with 0.2% CPU usage. Once it responded again, RAM dropped to 670 MB and CPU increased to ~10% momentarily.
Aside from the preinstalled ones, I only use "OctoPrint connection". I'm using a Crealtiy Ender 3 through that plugin, so that I can see the Webcam feed and control the nozzle/bed temperature in the "Monitor" tab.
ahoeben 1,986
