I I never enabled combing mode. In fact i avoid it like fire.
I created new machine FFF so that everything is at default so i wont have problems but i do instead.
It seems to be linked to angle for support.
Old cura would print support at 90 but new cura said it wont print at 90 so its like complete reverse or what ?
At 50 default there is no need any support since that wall side is perfectly flat. Why in the world does it add tgis weird string ?
burtoogle 505
You will need to set combing mode to "no skin" and also set max comb distance with no retract to a value > 0, typically 10 or 20.
