They are M3 screws (3mm - standard thread). With "socket cap" screw heads (although any head type should work). You can indeed measure the length and get similar ones (threading will probably run the length but that's fine).
Hey guys, sorry for delay in getting back to you.
I'll go and try those places then. Sounds like I just have to hunt for a raw screw then. I was hoping there would be standard place someone else had bought them from before to make life a little easier. These ones on the UM3 seem to be very soft, the UM2 ones I have seem to wear much better?
polygonfuture 9
Did you try contacting fbrc8.com? They are U.S. based part supplier. If they dont have it or can't get it, no one can. They ship super fast.
Last ditch effort would be to try McMaster-Carr, Fastenal, or Grainger. Can determine the thread size with a thread checker or calipers, and then measure the shoulder length, thread length, etc to get the exact screw you need.
