Thanks for the information!
So if I understand well: Gcode for a 2 used on a 2+ causes no problem, Gcode for a 2+ used on a 2 may cause a problem.
If we have a 2 and a 2+, it can be a good idea to only create Gcode for a 2 and use it on both printers.
Am I right?
ahoeben 1,981
Especially for PLA and models that aren’t too complex, the gcode is fairly interchangeable.
The 2+ has a better feeder, so Cura may produce gcode that has extrusion and retraction speeds that could cause some skipping on the extruder when printing with the UM2.
