I think only Protospace (FabLab Utrecht) made a 4 extruder machine as experiment. The reason why you can select it in Cura is because I wanted to design Cura around multiple-extruders, not just dual extrusion. So by already having the option to select up to 4 extruders I forced myself not to be limited to only dual-extrusion and this gives hardware tinkerers the option to move up to more extruders if they want.
Ultimaker however, only supports up to 2 extruders right now. The electronics are only suitable for up to 2 extruders.
codemaven 0
I can't say for sure, buy my guess is that this was on their minds when they originally designed it. There are now 3 and 4 extruder printers out there, but when the UM came out dual extrusion was rare and anything more was unheard of. I think that the designers of the UM originally may have planned for up to 4 extruders when they were initially designing it.
However... moving from concept to implementation is a whole different story... They originally only brought out a single extruder machine and though they may have intended it to be upgradeable to multiple extruders I think that proved in reality to be more difficult than expected. There were multiple changes to the print head during the course of the revisions which involved moving around the thermocouple amplifier and such... These incremental improvements were necessary just to get dual extrusion working. I don't think there is room (when you consider wiring, thermocouple amp, etc) for any more than two. Also, the addition of more bowden tubes will put extra strain on the movement of the head and could limit the speed that's possible.
That's not to mention the complexity of aligning two print heads... It just gets more complicated the more you add, and for little benefit.... Two extruders is a huge improvement over one... But, although 3 or 4 extruders would be cool, I don't think there are really that many practical uses that would justify the extra complexity. For me the biggest use case of dual extrusion is dissolvable supports. I can't see ever wanting to print more than two colours enough to justify the complexity... maybe 2 colours and a dissolvable support structure... another possibility is a head with a larger diameter nozzle for quicker in-fill printing... But I think I'm quite happy with two extruders for now...
Cheers,
Troy.
