I'm printing with one material and removed the other material from the printer. I also set the second material in the Cura software to the same material as the printed material. However, your answer was still helpful, as it made me try to deactivate material 2, which did the trick. I hope this bug will be fixed soon. Thanks!
1
fbrc8-erin 235
Are you printing with one material or two? Build plate temperature is a global setting; even if you've set 1 material to 0 degrees, if material 2 is set to 70 degrees it will default to the higher temperature since it's a shared setting.
