Problem with TPU
Arya
Posted · Problem with TPU
Hi everyone! I have some problems to print with TPU95A, I try literally everything but it seems nothing change.
I would like to obtain a simple parallelepiped scaffold (dimension: X=10mm; Y=10mm and Z=2mm) but the last layers printed are not perfect as if there isn't a good connection.
I have changed a lot of parameters, read all forums and topics but nothing.
The principal problem seems to be the non-adhesion between the last layers, as you can see in the pictures.
There are some parameters that I use/used:
Layer height: 0.1 but also try with 0.2 and 0.05;
Line width: 0.35/0.27;
Infill line: 1 mm;
Pattern: grid;
Temperature: 230° C (also 235 and 240);
Speed rate: 11 mm/s;
Build plate temperature: 60° (also try with cold plate and 70°);
Flow: 100% (try with 120%);
I also have modified some parameters for extrusion (also try without it) but nothing works. In addition a put some stick on the plate to have a good adhesion.
Any suggestions?
