Dim3nsioneer 556
Daid, thanks for the information. Please let me know if I can help you with tracking it down...
Well, I have been fixing so many things, not 100% if I fixed this already. You could give the latest test version (uploaded today) at http://software.ultimaker.com/Cura_closed_beta/%20a%20shot.
Just tried the 13.09 Pre-Release and it was causing some very aggressive jumps on the first few layers of my print... to the point that it would skip steps and end up printing layers all over the place. Not sure what's up. Print is now going fine with the same settings using 13.07 ST2.
Oh, a difference between the 13.07 and the 13.09 is that the first layer travel moves now happen at the full travel speed. I'm still not 100% sure if that's a good idea, as it might be easy to rip off the printed parts with this. I'm thinking about setting the travel speed to print speed for the first layer, and not doing any retractions. This should improve first layer adhesion I think.
It´s off-topic... but because you mentioned the 13.09 PreRelease and I looked into it. Please add the bridge speed settings from 13.04. - it´s so essential. Good work... keep ist up! thanks maxtex
Daid 301
There is a bug somewhere with the first layer and the minimal layer time. I've not tracked it down yet.
