Posted · Vertical lines on outer walls
Hi!
As you can see in the attached image, my 3d printed objects show unsightly vertical lines on outer walls.
Someone can help me to make the print better?
I use Cura 4.0.0 with my Anycubic Kossel Linear Plus.
Thanks!😀
    OK can you tell me please your settings for
    Line width
    Number of walls
    Infill overlap %
    Dimensional thickness of the part i.e. the external casing
    Extruder temp.
    Print speed(s)
    Also useful would be a pic of the model in Cura layer view, at a layer in the bottom half where the vertical lines are showing
    Hi!
    Line width: 0.4
    Wall line Count: 1 (this is what do you mean for "Number of walls"?)
    Infill overlap % 0.04
    Wall Thickness 0,4
    Extruder temp 230
    print speed 30
    The preview doesn't show defects apparently...
    Hi  @Tettaura   thanks for the info. OK several things going on here. You need 2 walls (yes “number of walls”), that is almost certainly your infill showing through the single wall. As you do not mention it then I assume you are using PLA and, if that is the case, then you are printing way too hot and you are over-extruding. Stupidly I did not ask for your layer height; even if you are using .3 layer height you should find that an extruder temp of 200 will be fine and gives you a big improvement. If your layer height is .2/.1 then 195/190 should be better. Of course if you are using ABS then your temp. is probably in the ball park but not for PLA. All printers and filaments are different so one cannot be totally prescriptive on extruder temp. but you should not need to move more than +/- 5 degrees on the above.
    Yes the preview will not show defect arising from the settings; only mesh defects in X-ray mode.
    Hi @yellowshark!
    Thank you for your answer!
    I'm printing with a PLA certified for food contact following the temperatures indicated in its technical data sheet.
    I will try anyway to lower them a little ...
    About the layer height, this is my Cura settings:
    Initial layer height 0,3
    Layer height 0,2
    Today I do some tests following your suggestions. I'll let you know as soon as possible! 😀
    Hmn, I have a specially manufactured PLA which has an anti-microbial additive mixed in, about 3% if I remember rightly, for use in the medical field, to prevent the transfer of microbes from one user to another. Of course they may not be but I suspect they will be similar. Anyway it did not impact my temperature to any great degree. I vaguely recall I may have changed the temp by 5 degrees but cannot remember whether that was + or - and I do not have the production notes on this laptop. At 30mm/s and 0.2 layer for normal PLA you should not really need more than 195, depending on how well your printer is setup. Adding another 35 degrees just seems too much to me  but then smart arses have been known to be wrong! I suggest you print some 10mm cubes at various temps and see how it goes - lol I will be interested to hear what your results are
