False detection of top layers
bkrahmer
Posted (edited) · False detection of top layers
I've got an issue where Cura 4.0 wants to falsely create top layers part-way through my model.  I feel like it's a bug, but just wanted to see if anybody had seen this before, and could tell me that I just need to tweak some settings.  I know I can set top layers to 0, and for this particular model, this would probably work.  However, if it's a bug, it would be great to see it addressed.  I have linked to some screenshots, and can make the file available to anyone that would want to debug the issue.
thanks, brian
Edited by bkrahmer
added images
    Ok, thanks for the information!  I've gotten conflicting information, because I have read that blender would show any faces with flipped normals in black.  I don't fully understand how normals work, so I've had to do some guesswork in my code.  If someone can tell me an algorithm for detecting if my normals are facing the right direction, or a further explanation of how Cura uses normals, it would be much appreciated.
    thanks, brian
    Edited by bkrahmer
