Yeah I kinda figured, that's why I was wondering if there was a plugin that would help out. The parts I make aren't complex just functional so even tho it would be time consuming it would be nice to have a report on different common settings I change to either cut time or improve the part or a compromise between the two. Even though the parts I make aren't complex they do take quite some time to print. Sometimes I forget to change a setting when comparing the different versions too. I suppose I could just use custom profiles and test them individually. I'm sure for what I need they might get out of hand too. I'll figure out something. Thanks for the reply. ☺️
nallath 1,125
There is no easy way to get this I'm afraid. We would need to slice something 3 times in order to get that info, so that will take a fair bit of work to get that functional.
