not sure what that means im pretty new to cura.
you mean overlapping faces?
around the eye are some areas where faces from the skull overlap with the eyeballs, yes.
the eyes are seperate in the original model for animation.
is there an option in cura to just ignore the internal structure?
to only look at the surface and treat the internal volume as solid?
Edited by Lightboxx
nallath 1,125
Did you check if the model is manifold? It looks like the model has errors in it.
