I've attached a sample of the problem. This object displays properly in Cura but the text is gone from the preview after slicing.
Hello @TomB19, I tried loading that obj file into cura and it complained saying the file was invalid.
I then loaded it into FreeCAD and exported it as an STL which cura did load but then complained that the model wasn't watertight.
I then checked the original obj model in FreeCAD and it showed these errors:
So perhaps the model needs fixing before you can print it?
Thank you for the help, burtoogle. 🙂
I'm pretty confident the problem is with the font. A different font solved the problem.
I thought it might be Cura, since it slices fine with Slic3r.
I can see the errors you indicate. Thanks for showing me this technique. I will play with the mesh and see if I can get this font working.
Cura is awesome. I really appreciate this tool. Thanks to all who have worked on it. I've only sliced a few dozen things and already love it, compared to my old slicer.
I don't see a way to mark this "SOLVED". If anyone finds this with a search, check your font. Cura is functioning fine in this situation.
Edited by TomB19
TomB19 0
I should mention I'm using Manjaro Linux. Kernel 4.19.42.
