Posted · cura gcode
Hello,
I would like to ask someone who could give gcode to put in to cura.
I need to check filament length being pushed by DDG feeder, so i want to make a mark on filament 10cm above core. i will take start point from tube.
So i need right a code in to cura extrude 10 cm filament before its starts print anything, also i need lower bed little bit for this 10cm .
Can some one right a code please 🙂
Thank you
    Posted · cura gcode
    It’s easier to use a tool like pronterface in the Printrun package. This gives you direct control to extrude a specific distance or move axes manually without writing gcode.
    it also gives you a terminal where you can directly enter google and see the response.
