same here,
Also tried right click toolpath print via USB and no print dialog box either.
Hope this is what you're after..
Loading # from disk...
Reading mesh from binary blob with 84012 vertexes
Loaded from disk in 0.016s
Analyzing and optimizing model...
Face counts: 28004 -> 27871 99.5%
Vertex counts: 84012 -> 13942 16.6%
Optimize model 0.047s
Slicing model...
Sliced model in 0.297s
Generating layer parts...
Generated layer parts in 0.156s
Generated inset in 1.187s
Generated up/down skin in 2.172s
Loading ## from disk...
Reading mesh from binary blob with 39624 vertexes
Reading mesh from binary blob with 44388 vertexes
Loaded from disk in 0.000s
Face counts: 13208 -> 13160 99.6%
Vertex counts: 39624 -> 6582 16.6%
Face counts: 14796 -> 14728 99.5%
Vertex counts: 44388 -> 7368 16.6%
Optimize model 0.046s
Slicing model...
Sliced model in 0.266s
Loaded from disk in 0.015s
Slicing model...
Slicing model...
Face counts: 13208 -> 13152 99.6%
Vertex counts: 39624 -> 6578 16.6%
Face counts: 14796 -> 14704 99.4%
Vertex counts: 44388 -> 7356 16.6%
Slicing model...
(<type 'exceptions.IOError'>, IOError(13, 'Permission denied'), <traceback object at 0x04D8FDC8>)
>>Traceback (most recent call last):
>> File "C:\Program Files (x86)\Cura_13.09-PreRelease\python\lib\runpy.py", line 162, in _run_module_as_main
>> "__main__", fname, loader, pkg_name)
>> File "C:\Program Files (x86)\Cura_13.09-PreRelease\python\lib\runpy.py", line 72, in _run_code
>> exec code in run_globals
>> File "C:\Program Files (x86)\Cura_13.09-PreRelease\Cura\cura.py", line 71, in <module>
>> main()
>> File "C:\Program Files (x86)\Cura_13.09-PreRelease\Cura\cura.py", line 41, in main
>> printWindow.startPrintInterface(options.printfile)
>> File "Cura\gui\printWindow.py", line 95, in startPrintInterface
>> printWindowHandle = printWindow()
>> File "Cura\gui\printWindow.py", line 204, in __init__
>> self.temperatureHeatUp = wx.Button(self.temperaturePanel, -1, int(profile.getProfileSettingFloat('print_temperature')) + 'C')
>>TypeError: unsupported operand type(s) for +: 'int' and 'str'
>> main()
Face counts: 13208 -> 13156 99.6%
Vertex counts: 39624 -> 6580 16.6%
Face counts: 14796 -> 14724 99.5%
Vertex counts: 44388 -> 7366 16.6%
Slicing model...
Sliced model in 0.188s
Generated layer parts in 1.109s
Generated inset in 1.547s
Generated up/down skin in 1.610s
Slicing model...
Generated inset in 1.188s
Slicing model...
Slicing model...
Slicing model...
File "Cura\gui\sceneView.py", line 645, in <lambda>
self.Bind(wx.EVT_MENU, lambda e: self._deleteObject(self._focusObj), menu.Append(-1, _("Delete object")))
File "Cura\gui\sceneView.py", line 525, in _deleteObject
self._scene.remove(obj)
File "Cura\util\objectScene.py", line 134, in remove
self._objectList.remove(obj)
ValueError: list.remove(x): x not in list
Slicing model...
Generated layer parts in 1.140s
Generated inset in 1.594s
Generated up/down skin in 1.594s
0
0
0
0
1
1
1
1
2
Daid 300
Not known by me. Can you check the output.txt in the cura installation folder, just copy the whole contents and post it here. Should help in diagnosing the problem.
