Thanks for your answer. This sounds plausible, although I didn't expect, that it would almost double the printing duration.
I'll make a test with long straight lines, where the acceleration shouldn't have that much influence and check, if the speed of the printhead will be the same.
Edited by fcrass
ahoeben 1,956
The printhead in the UM3 is much heavier than that of the UM2+. To maintain good printing quality, settings that affect the speed the head achieves are different between the two, eg the maximum accelleration.
Simply put, the UM2+ is a faster printer than the UM3.
Edited by ahoebenLink to post
