Same issue here since update to 5.2.11.20190503.
Jul 31 09:25:24 ultimakersystem-ccbdd3001057 python3[809]: 2019-07-31 09:25:24,815 WARNING faultHandler Added Fault: <Fault: level=4 code=48 message='Maximum probe height deviation of 1.32 exceeded between probes ProbePoint(loc:Vector2(40.0, 15.0), z:12.547 bed:59.59 °C, nozzle:195.50 °C) and ProbePoint(loc:Vector2(40.0, 175.0), z:10.041 bed:59.75 °C, nozzle:189.40 °C)' data='{}'>
In automatic leveling process (directly after manual leveling) the nozzles instead of touching the plate do stop about 10mm above the surface.
Regards
Edited by Nazdravi
Enigma_M4 125
the first thing I could imagine is an incorrect distance between the top of the base plate and the bottom of the heater plate, which should be approximately 14 mm for the auto leveling to work properly.
There exists a distance tool for easy adjustment:
https://www.youmagine.com/designs/um3-buildplate-distance-tool
Which error-number is the "out of reasonable" attached? Perhaps there is a helpful description and solution on the UM homepage, like for example this:
https://ultimaker.com/en/resources/47734-difference-between-detected-height-of-both-printcores-exceeds-realistic-values
Does your capacitive sensor work properly (can be checked in the diagnostics menue since last firmware)?
Regards
