Question regarding start scripts
MTG
Posted (edited) · Question regarding start scripts
Hey,
I'm using Cura 4.1 and Octoprint, so I have to use the start script function of Cura. With only one Material it wasn't a problem, but I have modiefied my UM 2+ Extended for dual printing. So I made a startup script for dual extrusion. It's basically just:
T0
//Extrude T1, Wipe and do stuff
T1
T0
As you See, I make sure that I have T0 selected, extrude and wipe, change to T1, do the same and back again to T0. Then I'm ready to start with T0.
So, when my part starts with T0, no problem here, everything is working normally. But when my part starts with T1, I mess up because my startup script ends with T0 and the Cura-generated toolchange is before the user startup script:
// How it is:
T1 //<- This is the Cura generated toolchange
//cura generated stuff like heating etc
; Start user startup script dual ---------------------------------------------------
T0 //My toolchange
//Extrude, wipe and stuff
T1 //My toolchange
T0 //My toolchange
As you see, it starts with T0 when it should actually start with T1. Now, I have to modify every gcode file by hand, if it starts with T1.
Why is it not like the following (or how can I make this work):
// How it should be:
T0 //My toolchange
T1 //My toolchange
T0 //My toolchange
; End user startup script dual ---------------------------------------------------
T1 //<- Here should be the the Cura generated toolchange
Wouldn't that be more logical for the final toolchange before the part starts?
I hope it's understandable what I mean
Edited by MTG
    Posted · Question regarding start scripts
    Use
    T{initial_extruder_nr}
    instead of the final
    T0
    Cura will fill in the extruder number of the first used extruder for the {initial_extruder_nr} part.
    • Thanks 1
    Oh, nice, I knew I couldnt be the only one facing this problem.
    Is there a way to only perform one part of the start script if only one Extruder is used, by the way?
    No, there is not.
