PETG BLOB
Ugh, just happened to me too, but not quite as bad. Generally, I heat the printhead to the appropriate temp, and then try to pull it off around the nozzle area. when it gets up higher like that, it's harder, and judicious application of a heat gun and tweezers/needle nose pliers to pull it off. Be careful not to melt/deform other plastic parts.
    Posted (edited) · PETG BLOB
    those braided insulations are for the heat core and are heat resistant. They won't melt like plastic insulation. If you do see plastic insulation though, be careful. Mostly you want to get it soft and pick it to pieces with tweezers.
     You can also use something like flush cutters to cut away some of the plastic, but if you get it warm, it might be easier to just pull it off.
    Edited by kevin-osborn
    added additiona info
    if you have a hot knife or soldering iron you can also kindof cut through it. I would try general heat first though.
    You can use a hair dryer to start. If you have a soldering hot air, you can direct it pretty specifically, but very high heat can be acheived. if you can get it just hot enough with a hair dryer, you may be able to soften it.
        • 27 replies
