CFFFP_Grinder_Bottom_Prototype1_V1.3mf
I should be able to print this without travels going over the holes along the perimeter or through the open space in the center right? Hopefully i'm not going mad trying to do accomplish something the software simply cannot accommodate at this time.
Thank you for your time and support!
burtoogle 515
Hello @Vinnycent, to understand your problem better it would help hugely if you could attach both the gcode file and also the Cura project file. To get that do File -> Save to produce a .3mf project file. Thanks.
