weak (small) pins on multiple abs print
Posted · weak (small) pins on multiple abs print
Hi guys,
need a little help with this one: small object needs te be printed (50 pieces)
printer: UM3 with closed cabin
Material: UM ABS black and/or CF NGEN black
I've managed so far to print a single strong version in NGEN but when I print 25pcs at a time the pins easily break off. With UM abs I haven't even succeeded in making one single strong print 😐
I've played with wall thickness, temperature, speed, infill overlap, infill and some other but i've got a feeling there is something I am not seeing... maybe simply too much once?
Anyone has a suggestion to increase strength of these tiny pins?
1-50x-halter_oled_256x64_cog_univision-original.stl UM3_dump.3mf
