A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
fbrc8-erin 270
It's definitely not quite the same. I think the pipe part is shorter on the UM2+ ones; I know the nozzle end is larger on the UMO.
Here's the github: https://github.com/Ultimaker/UltimakerOriginal
And here's the step file and PDF for the nozzles: https://github.com/Ultimaker/UltimakerOriginal/tree/master/1054_Nozzle_0.4mm
Your reseller should be able to order OEM nozzles in for you even if they don't regularly carry them. If you're in the US, I keep them in stock.
