I found it eventually. There is some strange behaviour with the input fields going on. So upon changing the value in the input field, the enter key does not set the changed value. The TAB key does set the changed value. If the value is changed and then the mouse is clicked elsewhere the change is reverted back.
Has anyone else found this behaviour to be very confusing?
shadowfiend 9
