Print with Solid bottom and Back
Ribby
Posted · Print with Solid bottom and Back
I have a few models that after being edited and are hollow on the back side, how would I go about making it print a solid back and bottom? Essentially trying to get it to look like Mr. Solo with a good base on the bottom with a solid back so you can not see the supporting material. Any Ideas?
