10 hours ago, gr5 said:Is the profile an "ini" file? If so you need cura 15.X which you can get here:
https://gr5.org/Ultimaker_Cura-15.04.06.exe
If the profile is a "3mf" file you can just open it with any text editor and jump to the bottom. The last few lines of the file explain the profile in human readable terms. Just read slowly and carefully.
It's says it's a .curaprofile. Not sure what to do with it. I can open it in notepad but it only has around 8 lines worth of stuff. I feel like there should be more.
gr5 2,224
