for processing a Lithophane you don't need a plugin, just use the open menu item to load a picture and a dialog box comes up.
You can find the Cura folder when you click on HELP and then "Show Configuration Folder".
To install plugins, use the marketplace in the upper right corner. There are plugins and material profiles to install. If you find a plugin which is not in the marketplace, download it and simply drag it onto the Cura window to install it.
Smithy 1,144
Hi
