Was just an idea with the couple, when it looks good, then there is no need to replace it. But keep in mind, from outside, it always looks good.
What about the filament, does it happen with other spools as well? Maybe you have one spool with a slightly bigger diameter?
1
Smithy 1,135
Is your hot end fan working properly, the middle one?
And what about your PTFE/TFM coupler, is it looking good? Maybe you should try to replace it.
Rabin_Dhamala 0
Yeah, no any issue with the fan. And I do have a spare PTFE/TFM coupler but the old one doesn't look that bad. But ok I will give a try....
