Posted
· CURA 4.2.1 vs 3.6 Print Time Discrepancies
I experienced this exact same issue. After almost ripping my hair off I think I may have found it.
First try enabling the outer wall speed and inner wall speed and modify.
Then you can also enable and increase the Top/Bottom Speed.
Lastly I found out that in CURA 3.6, if you set your own values for Top/Bottom Thickness the slicer will override the layer thickness you set in the beginning. I used to think I was printing at 0.2 mm layer height but in reality it was 0.302. Double check the total number of layers in CURA 3.6 and compare it to CURA 4.2.1.
Hope this helps!
casas_7 1
Hope this helps!
