CURA 4.3.0 Octoprint Connect, loses connection
RoboDLC
Posted · CURA 4.3.0 Octoprint Connect, loses connection
I have CURA 4.3.0 and Octoprint Connect plugin 3.5.9.
The plugin has random issues.  Often the Monitor page does not show the button to pre-heat the extruder.  When a print has been started, CURA will randomly lose connection with the printer.  When this happens I have to re-start CURA to "unclog" it so I can start another print.  The printer/Octoprint are working fine, CURA just does not connect to the printer.
Is there  a troubleshooting procedure or any ideas what might be going wrong?
Thanks,
DLC
