Here you go. I tried to remove the old cura folders but that did not seem to help.
Thank you
Bernie
Thank you
Bernie
I'm seeing some issues in the log, but I'm not quite sure if they are causing the issues;
- There is a (custom) plugin that is failing to be loaded called the "MKS Plugin".
- There is a printer that doesn't have a definition set called BIBO2. This is probably the result of manually adding a printer definition and not adding all the files it needs.
Those profile was added by the manufacturer. It works fine inversion 3, and does work in version 4 once you select a new printer and get past the wizard.
Same problem for me, only all the time not just after a windows restart. Cura worked great for about 2 weeks then started asking for setup again at nearly every launch. I've just started opening a half dozen instances of cura back-to-back and usually at least 1 of them will open the way it should, without asking to go through setup again. It's a ridiculous workaround, but it seems to work. Hopefully with the next update you can address this issue!
Edited by cambuehl
nallath 1,125
Could you share your log files?
My initial guess would be that it's failing to write files to your harddrive (since thats how the machines are stored).
