Attached is a screen shot of the printer settings for CR-10S on the left, and a custom FFF for the same printer on the right. Even though there is a huge difference between some of the speeds, the maximum X and Y speeds are still below the 100mm/s max that I am trying to use. Acceleration is 500 for the CR-120S definition, which is a little slower than the 800 - 1000 I normally use, but still doesn't seem like near enough to account for a threefold increase in print time. Default XY Jerk is 10 which is what I normally use anyway.
DivingDuck 79
Check your Cura printer profile with the plugin "Printer settings" of fieldOfView. Take a closer look for values of speed and acceleration and compare this with your firmware values. Then you know what's going on...
