S5 saying to install 5.2.11 when 5.4 is installed
Carla_Birch
Posted · S5 saying to install 5.2.11 when 5.4 is installed
1 hour ago, Smithy said:
I had the same and also asked me if there is a roll back. But it seems not, I guess it is a mistake.
Hopefully it gets fixed so i can return to 5.4 as i rolled back thinking they had pulled 5.4 due to some problem.
    There is actually a problem in 5.4, with the retract or too long retract at the end of a job. Seems not to happen every time, but there are some users which have reported it. The result of this bug is, that when starting a new print, the filament isn't transported far enough to extrude at the beginning.
    But I don't know if it is a mistake or if it is really a planned roll back. But it can't hurt to go back to 5.2.11.
