Where are the Settings "Minimum Support X/Y Distance", "Ignore Small Z Gaps", "Maximum Z Speed" and "Minimum Diameter" in the Tower-Support Section?
Posted (edited) · Where are the Settings "Minimum Support X/Y Distance", "Ignore Small Z Gaps", "Maximum Z Speed" and "Minimum Diameter" in the Tower-Support Section?
I can't find these settings in the "setting visibility" nor anywhere else.
Edited by Akashigiri
    Posted · Where are the Settings "Minimum Support X/Y Distance", "Ignore Small Z Gaps", "Maximum Z Speed" and "Minimum Diameter" in the Tower-Support Section?
    Make sure Cura shows all settings then you'll find them.
    Or use the search function
    Ok i have found the "Minimum support x/y distance" settings. But i can't find the rest. Maybe ultimaker changed the name of these settings?
    • 9 months later...
          • Heart
        • 7 replies
