sure, you just can use:
M190 S{material_bed_temperature-10}
if this is not working use M190 S{(material_bed_temperature-10)} at lease this was working
just be aware: if you use M190 to heat to a lower temp first (f.e to prevent a hot nozzle waiting for a hot bed) it takes a bit longer in total because the last 3-4° don't get heaten on 100%..
ahoeben 1,654
No, it is not possible to use math in the start gcode snippet like that.
