I'll try to find a simple model that exhibits this issue, it will likely take some time because it takes a long time to print and the issue, at least on the couple models I've been working with, doesn't manifest until well into the print. In this statue, the square base alone takes 5 hours to print. I'm currently printing a smaller version of this model that takes less than a day to print.
Although there are issues with the 4.2.1 print on the left, the difference with the banding in the 4.3 print on the right is clear. That said, I can't swear that every setting is identical.
My first print reverting back to 4.2.1 I only printed the top part, starting with where the bands had become prominent on the 4.3 print, that printed out without any noticeable banding, I only did some light sanding to produce what is shown in the photo below.
burtoogle 516
Hello @LindsayPatten, please slice a small model that has this problem using both 4.2.1 and 4.3 and attach the gcode files to this thread so they can be compared. Thanks.
