Posted · Cura turning temps to zero at start?
For some reason I can't figure out, Cura is turning the extruder temp and bed temp to zero after bed leveling and during the first layer of my print. I tested by printing with a temp tower gcode from Thingiverse so as to bypass Cura and it printed fine. I'm sure it's not in my start code, I disabled almost all of it to double check. I pulled the code from terminal in Octoprint and it's throwing a M140 and M104 S0...but why?
Recv: Bilinear Leveling Grid:
Recv:       0      1      2
Recv:  0 -0.286 +0.141 +0.555
Recv:  1 -0.367 -0.003 +0.374
Recv:  2 -0.480 -0.132 +0.162
Recv:
Recv: Subdivided with CATMULL ROM Leveling Grid:
Recv:         0        1        2        3        4        5        6
Recv:  0 -0.28625 -0.14324 -0.00023 +0.14125 +0.28019 +0.41759 +0.55500
Recv:  1 -0.31218 -0.17710 -0.04202 +0.09282 +0.22727 +0.36148 +0.49569
Recv:  2 -0.33810 -0.21095 -0.08380 +0.04440 +0.17436 +0.30537 +0.43639
Recv:  3 -0.36750 -0.24625 -0.12500 -0.00250 +0.12208 +0.24792 +0.37375
Recv:  4 -0.40269 -0.28395 -0.16521 -0.04685 +0.07087 +0.18821 +0.30556
Recv:  5 -0.44134 -0.32308 -0.20483 -0.08968 +0.02030 +0.12716 +0.23403
Recv:  6 -0.48000 -0.36222 -0.24444 -0.13250 -0.03028 +0.06611 +0.16250
Recv:
Recv: X:102.00 Y:200.00 Z:17.42 E:3204.68 Count X:16320 Y:32000 Z:13840
Recv: ok
Send: N15 M140 S0*81
Recv:  T:203.00 /205.00 B:64.50 /65.00 @:86 B@:127
Recv: ok
Send: N16 M104 S0*82
Recv: ok
    The partial log shows the M140 S0 and M104 S0 that you mention. It would be useful to know if they are also in the uploaded gcode. In the Files box on the left in OctoPrint, you can also download the gcode file. Please inspect it to see if the offending M104 and M104 are also in there. If not, it is not Cura doing this, but it might be something OctoPrint or a plugin in OctoPrint does.
    Hmm, you're right, I don't see it in the gcode file when I export it out of Cura?
    ;FLAVOR:Marlin
    ;TIME:49134
    ;Filament used: 17.9428m
    ;Layer height: 0.1
    ;MINX:21.415
    ;MINY:36.828
    ;MINZ:0.3
    ;MAXX:178.589
    ;MAXY:163.172
    ;MAXZ:39.8
    ;Generated with Cura_SteamEngine 4.3.0
    M140 S65
    M105
    M190 S65
    M104 S210
    M105
    M109 S210
    M82 ;absolute extrusion mode
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    G28 ; home all axes
    G29 ;bed levelling
    G1 Z0.2 F1200 ; raise nozzle
    G92 E0 ; reset extrusion distance
    G1 X10 ; move X-carriage 10mm to prep for wipe
    G1 Y100 E12 F600 ; purge nozzle & wipe
    G92 E0 ; reset extrusion distance from wipe action
    M900 K.07 ;set K-factor PLA
    M107
    M117 Printing...
    G92 E0
    G92 E0
    G1 F2400 E-2.5
    ;LAYER_COUNT:396
    ;LAYER:0
    M107
    G0 F3600 X59.607 Y39.25 Z0.3
    ;TYPE:SKIRT
    G1 F2400 E0
    G1 F1200 X59.646 Y39.211 E0.00275
    5 hours ago, ahoeben said:
    Try starting OctoPrint in safe mode. That (temporarily) disables all plugins. Check if the wrong temps are still sent
    Ok, printing through safe mode does NOT send the wrong temps. Think I should uninstall all the plugins and then reinstall them one by one?
    Instead of uninstalling them, you can also disable them and reenable them one by one.
    Awesome. Thanks for all your help!
    Just dropping this here. I have gotten this 2 times where hotend 1 reads zero. I had my ender 3 hooked up to my MacBook Air via USB. I preheated the hotend and cancelled the print and it seemed to start working again. Not sure why. I'm a novice but if another novice stumbles hopefully it fixes your situation
    USB printing is deprecated and no longer supported. It's a relic from a bygone era where printers were too stupid to even read a memory card themselves so had to be hand fed instructions one at a time.
    It's recommended that you should copy your gcode files to a memory card/USB drive/whatever your printer takes as it is much more reliable than printing over USB from your main computer.
