No real idea if this includes the Cura settings... but it is what was requested! Generated by file save in Cura.
VJM
Dear Burtoogle,
Please accept my apologies for the delay in replying, but the system would only allow me to post a restricted number of responses per day - frankly ridiculous!
I have duplicated your results with the printer set to 0.25mm nozzle in Cura, and indeed they are as you indicate. However, the problem slicing at larger nozzles remains, and Cura is definitely behind the curve on this issue, as I have limited problems with other slicers.
Using a 0.4mm nozzle and the results of slicing with Craftware, I can achieve acceptable results, as attached.
I remain of the view that the algorithm in Cura is failing in this area.
It would be interesting to s Ultimaker is interested in investigating this issue...
Many thanks again,
VJM
burtoogle 495
Hello @VJM787, please save the project file (File -> Save) and attach the resulting .3mf file to this thread. That way we get to see the model and the settings used. Thanks.
