Well there are a host of things you can play with to try to improve aspects but I think the two biggest rules are print slow and cool. Also the particular filament you will use can have an impact. Different coloured filaments from the same supplier can produce differences. Also easier if you design your models yourself. E.G. easier to print accurate 0.4 walls if they are 0.4 and not 5.3.
I would recommend speed not above 30mm/s. For temp. use the filament you will use and print a series of 10mm cubes to find your temp. Print each cube at 5 degrees cooler than the previous one until you see evidence of under extrusion. Add 5 degrees to that temp. to get your desired temp.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
yellowshark 153
