Hi Nick, thanks for the response, I have tried an old file which was something I made a while ago and the printer starts it OK so I guess the printer is alright.
I have enclosed the settings, the file was created in mm in Auto Fusion 360, I used Cura v4.0 but upgared to 4.3 after the problems occured but its still the same.
1
NickB 2
For your question about not printing in the center I think you need to change this setting for your printer
But the scaling part I am not sure.
Does cura show the right dimensions if not it is most likely a problem with exporing the part form Fusion
You could check if you are exporting in the right dimenions so: mm or inches.
when you go to export (as stl) I belief there is a tab named 'settings' where you can change a lot of thing (not sure about this though)
