Problem occured at work where IT gives restricted rigths to install softwares, I will try it when 4.4 is officially realesed.
In the meantime I will try it on both 4.3 and 4.4 at home this evening.
Well made the test at home,
With Cura 4.3 thsame problem occurs. Cura crashes if I create a new material and put "Generic" as brand.
Uninstalled Cura 4.3 and installed Cura 4.4, it works fine. So seems like it has been corrected in the new version.
nallath 1,120
I don't have 4.3 installed, so I tried to do it in 4.4 (which is in beta now). I managed to create the material without issues. Could you try if it works for you in 4.4 as well?
