Thank you for your answer.
What should i do, when i have the same printer and add 3 "machines" with different noozle?
Check Cura if i connect the printer with usb and set every one of this 3 virtuell machines to "connected"?
I don’t use usb printing much -if at all- but I think they all connect to the same one.
Ok, thank you! i will try it.
Best regards
ahoeben 1,654
The current version of Cura does not have manual port selection, only automatic port discovery. If that does not work, unfortunately you can not currently use Cura to flash the firmware.
