Thank you for the response and the warning about fire!
It hasn't happened again so not sure wtf that was about. It was a very cold day and the wind was blowing somewhat at it so maybe just couldn't reach temp that day? Thanks again
pbackx 11
This message is a safeguard. It indicates that your printer has been heating the nozzle for some time, but the measured temperature is not rising.
This can happen when the temperature measurement is broken. If the printer would not shut down in that case, it could cause a fire.
In your case, you are probably getting this error because the printer is unable to reach the requested temperature. Check your printer's specifications and maybe contact your seller.
