Posted · Cura 4.4 Support Oddity
Sadly this is the stair-stepping again (somehow). I think we should look into rethinking that whole piece of code, given the amount of trouble it causes us and how hard it is to debug.
It does, most of the time, give a nice workaround though: Just put 'support stair step height' to 0.0 mm and the missing support will appear.
Posted (edited) · Cura 4.4 Support Oddity
@rburema - Thank you for the work around. This worked for me.
@territerriterri - Is 6989 a GitHub issue or do you track these elsewhere?
For what its worth, I like the stairstep at .1mm. Having to go 0 to solve this issue does look like the support is going to hug right up against my part.
Edited by hartparr
    The CURA-6989 is an internal ticket for us in the Cura team in Ultimaker. We usually put it here so if a dev or QA engineer revisits this, they can refer it to an internal ticket. 😉 I'm glad @rburema's workaround worked for you. We are going to revisit the whole support generation feature, please bear with us! 🙂
