Print changing based on number of objects
kuresimon
Posted · Print changing based on number of objects
I have a problem with CURA, i have tried in both version 4.4 and 4.3, but the same problem occurs in both.
The problem is that I need to print a lot of the same object. It works fine if I slice the object alone, but if I add multiple versions of the same object it removes an importent part.
image.thumb.png.eee6e419a081a2be8e6751d501e63658.pngThis picture illustrates how it is suposed to look, and how it looks when only one object is sliced.
image.thumb.png.f7a3e8ff86024329bb5aeed993077e19.pngThis picture illustrates how it looks if I slice multiple of the object.
As you can see, when slicing more of the object it removes the middle hole.
Does anybody have a fix for this problem?
