Thank you for your response. What isn't broken in windows! 🤬 I wonder if there are enough people that would be interested in something like this to make a formal feature request????
Wayne
Wayne
It would require a big architectural change to support this officially. I don’t think it will happen soon.
While I don't need to run more than one instance of Cura, it would be really helpful for my multiple machine workflow to be able to write a 'start-up' script that can be called from the command line. That way I can click on a shortcut on my desktop and have cura run a start-up script set for machine #1 and another start-up script for machine #2. The scripts would primarily set machine names, default profile for that machine, and perhaps input and output paths.
That would be sweet.
ahoeben 1,968
Yes, but not for what you want to achieve. Running multiple instances is a workflow that is not supported and that will cause subtle issues (eg the preferences and settings of the last Cura instance that is closed will overwrite what is written by the other instance(s)).
The current commandline options are listed here, but I think they are broken on Windows:
https://github.com/Ultimaker/Uranium/blob/35ba8c5687a540a0f3df055a421373e96d30c606/UM/Application.py#L109
