How to prevent specific print path
wal_ter
Posted · How to prevent specific print path
Hi everyone,
I did not finde a good title. Any Ideas?
I want to print the following structure with Cura 4.4. The structure is almost cylindrical.
It is slightly conical with a 0,5 degree draft angle.
The diameter at the bottom of the structure is 3mm.
It is part of a case where a screw will be screwed in.
The next image shows a cross section of the lower area.
I print with a 0.2mm nozzle.
The yellow print path lead to problems. It is not circular like the green and red paths.
Does anyone know how to prevent the yellow print paths?
I would like to have circular print paths at the whole cross section.
