Retraction optimization
duesentrieb
Posted · Retraction optimization
It would be tricky to mount a bigger than 5cm fan without restricting the X/Y movement (fan bumps into UM walls before nozzle reaches destination).
Maybe you could look at a smaller radial fan if you want supply more air.
Good luck and keep us informed with your progress.
ARGH... I knew I had overlooked something... Damn... But luck is with the foolish, I think I have some mm left. So it might work out, but will be tricky, you are right. I think I will give it a try. It will take some time. I will keep you posted.
        • 1 reply
